Mooky
Hi all, ok I picked up a new truck for the shop...1956 dodge 1/2 ton step...has a 440/727 in it...if you put the trans into Drive or 2nd it makes a horrible whining/buzz mix sound inside the cab and acts as if it were slipping....now if you put it into 1st and manually shift through the gears it will drive and shift good but still has the whine in 2nd and 3rd...any thoughts? all help is appreciated and thanks in advance.
