MprDoc
OK, so my motor has been out of the car for almost two years now. I have it torn down to the short block with the timing chain set installed but as I was installing the chain set it I noticed the motor felt like it was turning kind of stiff.
Could this be an issue if I drop the motor in, prime it and start it? Should I tear it down and throw some oil or assembly lube on the rotating parts to make sure everything is all lubed up as a precaution??
