Moulding Clip Experts 62-65!
JPrusinows
6:45 AM
Biloxi, MS
Calling all 62-65 aficionados, experts, fanatics, and anything else in between! LOL. Desperately seeking info on what clip and availability of said clip is used on the 62's for the beltline rear quarter moulding finish piece. I know it is a push in type due the size of the hole as opposed the screw and nut clips used in the trunk, etc. I have attached photos of the trim piece front and back, where it goes and the hole size, as well an old clip that I believe is in the same family but a different size. Any help greatly appreciated.
Thank you much and in advance,
Jeff
Contact Jim Kramer @ if Joe can't help you...
If those guys don't have it then you will most likely have to make it. Hopefully you can get to the back side with the door panel off.
