Mounting a A833 to an engine stand
70chall440
7:57 PM
Yelm, Washington
Has anyone ever done this? I am thinking for cleaning, repairing, and/or painting. It seems like the ears should be strong enough but I am not willing to be the test case to see if they are. I could of course also incorporate a tail shaft support and then I know it would be good but I was just wondering if anyone has done this (mounting the trans to some type of stand).
I have one hanging on an engine stand via the bell housing. Works well.
Just set it on the bench instead of going to all that hassle for nothing. When its time for paint, set two chunks of 2x4 across a steel pail and set the trans face down on those. You don't want to paint the face anyway.
I think I need to open it up and was thinking that a stand would be more convenient than the bench
Might be a little difficult because I seem to need to flop it around a few ways to get where I need to be.
Kind of why the stand idea came about, if I could rotate it it might make it a little easier to work on.
In the time it takes to **** around with **** to mount it on a stand you could have done the complete rebuild.
Yeah, you'll be the first guy to ever flop a tranny around !!!
Over the years how many do you think got built an a bench and how many on an engine stand. Man up !!
No problem all, it was just an idea that came to me. Iv'e never rebuilt one completely, I have put synchors in one. In this case I was thinking it would be more convenient to clean it and if necessary rebuilt it.
This trans came out of I believe a 68/9 RR that had gotten hit in the front and the input shaft cover was cracked, so the insurance company bought the guy a new trans and it was replaced at the body shop where it was left for about 30 years. The body shop owner who is a friend of mine is a GM guy and had it laying around, ended up giving it to me.
Most pain in the *** part I have run into in the few I've done was lining the main shaft and its components back into the needle bearings in the back of the input shaft. Takes a bit of finesse and can give you fits but all in all many ways to skin the old cat.
I actually find it easier to work on the 4-speed on a benchtop - they can be mounted via the mounting ears (i only do that on iron cases) - the benchtop allows you to move it around easier -
Thanks all, I am going to open it up and see what it looks like as well as put a dial indicator on the input shaft to see if it is remotely round.
Tried it on a stand, not much you can do mechanically but for painting it works
I think I bolts a short 2x4 to the bottom side that did not extend beyond the sides to keep it from rolling and that was all.
