Mounting radial slicks
bobs63wagon
1:34 AM
Minnesota
Mounting Hoosier nine inch on my ten inch Draglite rims. Have decided not to use rim screws as it sounds not recommended with radials. What are some of you guys using to help seal the bead? I've heard many versions. Nothing at all, High Tack (then hard to get off the rim), and several other ideas. Thanks.
The Dodge Demon challenger- the factory sandblasted the bead seat to keep the tires for spinning on the edge. Gave a rough finish for the rubber to hold.
we use a little bead sealer also, been running radials for many years.
