No leaking from the gear or pump. This was a driving, functioning car
***NEW ADDITIONS ***
Wheel set - 80% + tread left 5x4.5 lug pattern 255/60R15 Rears 235/60R15 Fronts - 500
used original splash guards ( front corners under frame rails)
stock used 727- 8.75 drive shaft
vacuum canister ( for headlight doors )
Original vacuum hoses ( for head light doors ) complete
ANY FRONT END SUSPENSION PIECE - TBD
stock intake manifold - 65
stock heads - 85
stock 383
valve covers - 25
used 383 headers ( needs media blasting, rusty ) - 50
used fan off a 383 - 15
steering gear with
pitman arm - 100
Saginaw power steering pump - 40
steering wheel horn ring - 25
steering column- column shift- ( with aftermarket wheel) - 150
rear window glass ( used ) - 100
used
alternator - 25
lower a/c vents ( PAIR ) - 40
dash a/c selector - 100
radio speaker knob and plate - 50
OEM used
brake booster - 30
8.75 complete rear axle - 3.23 ratio - 250
original rear leaf springs - 100 ( set)
used 5x4.5 bolt pattern vector style wheel set ( widened lug holes , wide rears) - 400
sun visor set ( some stitching coming loose) - 35
fenders ( driver & pass ) spots need repair 150 ( each )
glove box door ( needs dye job) - 75
used original parking lens set - 25
68 chrome ribbed console top - 3 piece set - ( good amount of pitting ) - 125
inner windshield trim to headliner - 65
dome light - 30
rear bumper ( great core, needs refinishing ) - 150
68 charger grille support - 100
upper quarter window pad set ( needs refinishing ) - 200 (set)
Original chrome auto console shifter - 50
Auto shifter console top w/ indicator - 60
68' charger torsion bars ( set ) - 50
