Next it’s time to concour the door hinges. The hinges this car came with were on the rough side but, still worth trying to repair. The lower hinge on both the drivers and passenger side was cracked right where the hinge forms an L.
First was to dissassemble each hinge. I sand blasted the hinges while they were together but, will go over them again while apart. To punch the pins out, I just used a flat punch and a hammer. To repair the cracked hinge, we took a Dremal and made a “V” where the crack was. Once the prep work was done, it was time to crank up the welder and fill in the void/crack.
The hinge rebuild kit came with an arbor bit, oversized pins for the lower hinges, bushing and standard pins for the upper pins and new S springs.
To remove the rollers, just take a grinder and grind the pin flush with the hinge body. Then, take a center punch and knock them out. They eventually come out...
The inner hinge was loose in the outer hinge body so, we tossed the hinge body in the press and gently squeezed them back together to take most of the slop out.
The original wavy washers were rusted away for the most part, I found a complete assortment on Amazon for $8.00.
After sand blasting each piece, replaced the washers, added a little grease then tapped the rollers/pins back in their holes. To keep them from coming out, I tacked the end of the pins with the welder. Once all of that was done, each piece was sanded down, wiped off with wax/grease remover and epoxy primed.
Now, this is the finished product.
