PFG MOPAR
Went to drop off the girlfriends cat at the vet on Tuesday, got back in the car, it wouldn't start.
( 29k original miles, 318 2 barrel stock.... was running perfectly until then.)
Assumed I was "just" out of gas, as the gauge was on dead "E" .. Called a buddy to bring me some gas.
An hour and a few gallons latter, car still would not start. Buddy had a test light, determined the ballast resistor was bad.
When and bought/installed ballast resistor. Car started.. Not well. Backfire through carb, rough idle, couldn't even put it in gear without stalling. Limped car over to a friends garage, dying at every light/intersection I came too. No power.. hesitation.
Replaced aftermarket coil with the original.. Same
Replaced reluctor pickup.. same.
Went and got a control module from Autozone. Cheap chinese crap .. Car wouldn't even start with it.
Returned said module (5wire) and bought another (4 wire!, original was a 5.) from a different Autozone. friend that works there said it was a replacement for the 5 wire !? Installed it and car started and ran better. Re-timed it and all seemed well. Power back, no dead spots. Went out yesterday and tried/finally started the car, backfire through carb, running like crap still.
Almost seems like a fuel problem.. The fuel pump is new and working. Had NO problems before this "event" ..
Anyone have a clue what the problem could be?
:sad4:
Thanks any and all ..
Mike..
:sad4:
Mike..
