daniel_depetro
- 6:52 AM
- Jul 22, 2008
- Sterling Heights, MI 48310
I purchased a bottle of Redline 'water wetter' since I was changing the coolant and 440s produce some serious heat/under hood temperatures.
I also picked up this Stant SuperStat 180 degree premium lifetime warranty thermostat.
Felpro premium water outlet (thermostat) gasket
I decided to install my lightweight aluminum high flow water pump and lightweight aluminum housing at the same time. The aluminum water pump housing alone weighs ~10 lbs. less than the factory cast iron piece.
When I was putting the original cast iron thermostat housing back onto the car my father said "I can't believe you're going to put that 'heavy' thing back on there?". He gives me grief whenever I try to lighten a car up a bit. I said "it's all I got", so he went to the corner of the shop where some of his big block stuff is and dug out a couple of original lightweight aluminum units.
Free score!
Since the coolant will have to be drained down far enough to install the water pump housing, it would be an opportune time to drain it completely and install my aluminum radiator.
This new aluminum radiator should be a huge help keeping the temperatures down on this big block.
This is just a ~$200.00 shipped universal fit eBay aluminum radiator so I will need to fabricate some way to mount it. Then comes the fun task of finding hoses that properly fit.
The dilemma is the radiator support. Because this car was born with a six cylinder engine it has the small (22") opening radiator support and matching small 22-inch radiator.
In order to make full use of this new aluminum radiator the car (radiator support) will have to be opened up on both sides. I'm not going to cut anything on this car, even if it is to make it better.
The aluminum radiator is a lot lighter then the copper/brass factory piece when both are empty, however it is much larger which means it holds more water. So I doubt there will be any weight savings, and it possibly could be ~5 lbs. heavier once installed and the coolant is topped off.
Like the rest of the parts for this build I already had this radiator sitting in the box awaiting installation in another project. I thought it would be better to use these parts up instead of sitting around as you never know what may happen. The actual radiator measures 19" high x 27" wide x 3" thick.
![redlinewaterwettermb8.jpg](/moparforum/proxy.php?image=http%3A%2F%2Fimg183.imageshack.us%2Fimg183%2F1097%2Fredlinewaterwettermb8.jpg&hash=b271b005e55213f793805094d620fecc)
![45358ek1.jpg](/moparforum/proxy.php?image=http%3A%2F%2Fimg183.imageshack.us%2Fimg183%2F3742%2F45358ek1.jpg&hash=54d2ab13784e4f74d6a511455710f3f0)
![felprowaterhousinggaskeet4.jpg](/moparforum/proxy.php?image=http%3A%2F%2Fimg183.imageshack.us%2Fimg183%2F9061%2Ffelprowaterhousinggaskeet4.jpg&hash=4456bc86fdddda0350bf37dfe6d95634)
![bigblockmoparaluminumhi.jpg](/moparforum/proxy.php?image=http%3A%2F%2Fimg183.imageshack.us%2Fimg183%2F6296%2Fbigblockmoparaluminumhi.jpg&hash=f6a13a2937e2389838abdb7e20a50b56)
Free score!
![440aluminumthermostatho.jpg](/moparforum/proxy.php?image=http%3A%2F%2Fimg203.imageshack.us%2Fimg203%2F5205%2F440aluminumthermostatho.jpg&hash=c43677078f99ca8706312a9c59094bc6)
![19x28x3aluminumbigblockkh3.jpg](/moparforum/proxy.php?image=http%3A%2F%2Fimg363.imageshack.us%2Fimg363%2F7282%2F19x28x3aluminumbigblockkh3.jpg&hash=bd67a87d8c88036f78372152e0b48b72)
