- 1:31 AM
- Dec 31, 2020
- Ontario, Canada
I threw up in my mouth a little bit, when I saw that!
That was to close. Glad it missed the car.A bolt on one of the rollers came loose. Because the top of the door is connected to the opener, that prevented the door from falling on my RT. Had it back in place in 30 minutes. It missed the top of the car by a foot
I've done a little bit of garage door work over the years and yes, the panels are NOT light at all.....especially the ones that are insulated double wall panels!Last winter my 14x12 shop door came off the track. I was trying to get it back when all hell broke loose and I found myself on the floor under 3 panels. Let me tell you, they are heavy.
Sounds like the opener actually saved the day. It wasn't what failed.Lucky, Why I have no garage door openers in my shop!
Well it did keep it off the car. Point was, if you open them by hand that **** don't happen in the first place.Sounds like the opener actually saved the day. It wasn't what failed.
Point was - the thing came down regardless of whether or not it had an opener on it - and in fact, he was lucky itWell it did keep it off the car. Point was, if you open them by hand that **** don't happen in the first place.
Biggest issue with openers up here in the Winter. Open door, pull vehicle in, slush and **** melts and runs back under the door seal and freezes it down. You hit the opener button, door is frozen in place and the top panel of the door gets buckled in half or the door suddenly pops free and jumps the spring drum cables off the cable holder wheels.
Yup insulated double wall. I was pretty sore for a weekI've done a little bit of garage door work over the years and yes, the panels are NOT light at all.....especially the ones that are insulated double wall panels!
