Need advice for 400 build
Oh and I did all my own assembly, and parts running. Keep an eye on your local C/List. I got some good deals there.
Don't discount buying an engine that has just been built and being sold cuz someone needs money. Always seems to be a good deal out there. just get documentation from builder.
I didn't think the 700 dbl pump Holley was big enough, so went to a 780 vac secondary model 3310 on my 451. It runs even better now, and no flat spot! I traded the 400 rods for it, that were left over from my build. So if you watch the forums and C/List, you can do some trading and get the parts you want a little cheaper.
Thanks for all the input. I do not plan on ever running the engine over 5500 RPM, just want a a good running engine with good torque and reliability. I am not looking for lowest cost, but best bang for my buck. Can I make good torque and ~400 HP for less than $5,000? Less than $4000? (with someone else building the engine)
Another way to ask....What do I need to do to whip Chevelle 383 stroker and a el camino with a 350 HP fuelie GM crate motor? :eek:)
Then you want to make sure you use the 400 rod with the 440 crank
