Need Air Compressor Advice
dspur
7:30 PM
Albertville, AL
My needs: for my shop but primarily to run the blast cabinet, and occasional use at that. A 20 gallon Kobalt (Lowes) is super loud and woefully inadequate. I’m tired of blasting for 15 seconds and then stopping to let it catch up.
I’d like something that is dependable and will do the job, but at a price point that is commensurate with the occasional use.
TIA
A blast cabinet will require a large amount of air. The larger the cabinet the higher the demand. IMO you are going to want as large a tank as you can afford or have space for, or a screw compressor that can keep up and not make you go deaf while doing so
The CFM you needs depends somewhat upon the tip size of your blasting nozzle. I run a TP Tools blast cabinet with a 21CFM compressor and it keeps up without issue. I have to stop more often because I'm using older media and the vacuum cannot suck the dust out fast enough. If you are doing large pieces having to stop repeatedly is a hassle, if you are working on smalls and bolts, nuts, etc. you'll be stopping more often anyway. Most upright compressors take up about the same amount of room, i'd get the highest CFM you can afford.
I second the recommendation of more storage. Look for dead compressors with good tanks and several can be plumbed together for extra volume. I fell into a nice little 500 gallon tank for my shop!
Mike
If you're doing a lot of blasting, painting and other high volume stuff, you'll need a good one. I'm happy with my Champion.
Most noise from the compressor is from the intake. Plumbing the intake to a fresh air supply outside the room significantly reduces the noise and keeps the tank air from being contaminated by what's in the shop air. If the air is to be used for painting this is critical.
For sure you want a 2 stage. My 30 year old Quincy QT-5 is 175 psi at 17.5 cfm. No problems with keeping up with blast cabinet.
A blast cabinet can exhaust an 80 gallon tank immediately!
Therefore, gallon capacity is somewhat meaningless.
CFM@90 psi is KING for a compressor used for blasting.
I use a true 5HP motor, two stage pump rated between 18 and 32 CFM@90 (Bel-Aire model 338 converted to single phase 240V).
Depending on what I'm blasting, it can run continuously until I release the trigger.
For a while I had a backup DeWalt 9.8 CFM unit that was barely adequate to blast small parts like brackets.
Buy the most CFM@90 you can afford.
I personally would not even attempt operating a blast cabinet on a regular basis with under 12 CFM@90 psi.
What is your budget? Quincy and Bel-Air are great brands but pricy.
I could buy whatever, but it is for occasional use. This is a personal shop where I get my "therapy" in restoring my super bee and a mustang, not professional use. There are times I have a good bit of brackets and other miscellaneous parts to media blast, occasionally tires,to inflate and other miscellaneous uses. I rarely use any air tools, my impacts are battery. I am just tired of a small, old failing air compressor blasting for about 20 seconds and then wait several minutes for it to catch up.
Having said all of that my interest would be +/- 1k, possibly more but I am not looking for nor do I feel I need a 2k compressor. I have been looking at mostly 60 gallon, single stage, with 11.5 cfm at 90psi. I would prefer more, but again, occasional use. I have considered a DeWalt with the 5 hp, 60 gallon and I think around 15 or so cfm @90. Somewhere plus or minus $1300.
Most of the 60 gallon tanks are going to be comparable in specs. I have the below compressor my wife got me several years ago for my birthday. 230v so I ran a dedicated circuit for it. I've painted a car and ran my blast cabinet, ran air tools. Whatever you do purchase, get the true 3/8 airhose and Milton high flow fittings (if you don't have them already.)
Quincey is the Cadillac....... I see one pop up on Craigslist now and then....... I'd favor my 1982 model 325 over anything....... designed to run 24/7/365 minus maintenance
I could have scored this one for a grand, but missed it by an hour :BangHead:
Thanks. I’ve looked at the Dewault Is this the 3.7 hp or 5; rated at 11.5 cfm @90 psi?
Yeah, who scraps that?
the californy guys must be made of money :mad:
Actually it was in a local firehouse... They got a new rotary compressor... I should have kept it but my stuff was already set up & my buddy's compressor died....
I got this bad boy about 8 years ago. No problem keeping up with my blast cabinet.
