Red63440
512 stroker kit in rb block,11 to 1cr,indy EZ cnc maxwedge port eqaulized chambers at 83cc,640 lift solid roller low 260'[email protected] on in take and high
260'[email protected] on the exhaust,indy dual plane will work better for street the single plane 4150 flange will work better at track,T&D rockers or harland sharp minimum,829-16 comp roller lifters,Smith bros push rods,isky springs 9315 work well for street use and clearance issues.Make sure to get the valley tray with the access plate.You will have to service the lifters every so often.
Your car is probably 3850# use a 4.30 gear 29.5x10.0 tire or 30"tall tire,3500 converter or 91/2 about 4200rpmThat depends on the intake setup.
These are parts that I use personally and have great success with!Hope this strikes your intrest and lights the fire for ya!!!
Weight would be closer to 3400 and 4.30's will be way to high for street use. We have a ton of freeways around here and with 3.91's I was turning about 4500 rpms.
