mstephens6900
Did a swap in my 74 Satellite from the 318 to a mild 383. Now I'm hooking everything back up to find the 383 is still points. What are my options ?
I run points because I grew up on them... cars ran over 80 years on points... keep a spare set in the glove box learn to set them... a new distributor is around $50-100... I have used them on engines that have tached over 9000 rpm and have had the contacts plated with platinum at a jewellers. Some of the old NHRA junk would run dual dual point distributors and get incredible results.... but for the plug-in play guys who don't have a lot of mechanical ability electronic is the way to go.
In terms of performance the modern hemi is lighter, more efficient and makes more power. Comparing the two based solely on their intended function the 426 is junk.
Points work but you need to "trick" them out to get the them to last and there is still a cam block that opens and closes the points that can wear. That being said. Everyone should have a point dizzy. In case of emp blast or nuclear war, a car with carb, points and mechanical fuel pump will still run.
I have restored a distributor and replaced points for a cost of about $75 for every 50 years or 500,000 miles... on one old dodge brothers farm truck from the 30's that original distributor had 180+ k on with countless hours ideling...it and was last running in 2010 with only 3sets of new points in it and there was John Deere twin cylinder popper that was traded from farm to farm that has so many hours and been rebuild it would be impossible to guess.... then sat for decades and with some emery cloth and some WD 40 a cap and button which an electronic would need any way... ran like New... the rest of the machine had $1000's and months into working... I would not expect to see nearly a century from an electronic box for the s same money that a points will go for. Just throwing away a points distributor every time would still be cheaper but you can rebuild one faster than the parts store can get you in and out the door with an electronic set up.Electronic is maintenance free so I dont see how points are cheaper to maintain.
hehe. Get 'em, sleepar!
Facts are facts. YOU can fix a point system. You can only REPLACE electronic.
I have run both and have had the boxes fail and had new ones fail out of the box... with the box I could only run a 30,000 volt coil and the points can handle a 45,000 volt one I have had points fail also but a little scuffing with fine sand paper and I'm off again. I can adjust the dwel and point gap indefinitely where the box is non adjustable it's an emissions gimmick like CAP or lean burn.... do the Pepsi challenge and get a dual point distributor all else being equal and a feel meter and go by the book and you won't notice a measurable difference and if any gain will be on the points set up.Ive never replaced a pickup, and I think ive had one ecu fail on me an it was a crappy orange box that was exposed to the elements. Thats in 25 years. You can get a good stock one for 30 bucks and change it on the side of the road in 3 minutes if by chance it leaves you sitting. Electronic ignition gives you more precise hotter spark. This gives you more power and better economy.
