Newkidonthebloc
Hello everyone,
A quick disclaimer: I am completely new to the hobby. Everything I do is my first time. I try to do everything by the book and correct but a lack of experience and being a numbers guy probably makes me too cautious and prevents me from driving the car as much as I would like too.
Today I checked the timing (with out vacuum advance hooked up). There is quite some play in the timing chain but the car idles around 10 degrees and at 2500 rpm the timing is roughly 34 degrees. I'm fine being on the safe side of it. Engine is old/ slightly tired and the car is just a driver (for now). I am not looking for performance but I am scared for predetonation ruining my engine. It is a 383 2-barrel that now has a 4-barrel, intake and headers but I believe the rest to be stock.
So.. here is my problem: When I drive around 30-40 mph and let off the gas or touching the gas just slightly to maintain the speed I hear a faint sound that resembles (what I think) ignition. The sound is very constant (every cylinder seems to produce it) and I am worried that it might be predetonation happening. The engine sounds fine when I step on the gas or drive with more throttle engaged.
I am thinking that this might be caused by the vacuum advance since it only happens with out / or with slight throttle. However, reading about timing has taught me that pinging usually checked during acceleration or with a fair amount of load on the engine.
Driving around with the vacuum advance disconnected made the car run worse but it did get rid of this sound...
Could the vacuum advance be the problem and/or is it normal to hear this?
I'd love to hear what the more experienced think about this.
Best regards and thanks in advance (pun intended ;)
