Need front suspension boots and seals
If you got all the OEM size ball joints/tie rod ends/Pitman-idler arm, I don't see why it wouldn't. Just throwing this out there.....If your seals are shot, myself I would be wondering what's the condition of the metal underneath that the boots where there to protect-hold in the grease? Obviously the rubber is worn, is the joint?
The thing is ...
I had to remove my steering arm in order to drop my oil pan and I tore the rubber covers getting the tie rods and pitman/idler arm loose. Seals are fine I just need the covers and I can't find the pitman/idler arm covers sold separately.
Just keep in mind the covers only fit the oe joints-not aftermarket ones.
Use the Energy suspension boots you can order from Advance Auto for a few dollars for a package of two. The part number is something like 913101g. I use them on all four connections to the steering link and they work perfectly fine.
I ordered the package above (had to have them for this weekend) and they arrived yesterday. I will everyone know how things turn out.
