mvandale
I believe I hear two noises. One sure sounds like valve train. The other might be piston. The one clue is what you said about pulling the spark on number one and how it changes when you put the wire on. You could run it with the left valve cover off to see if anything can be seen. You could unhook the coil and see if you hear anything while cranking it. You sure do not want to run it like that.
Yup, ran it with valve cover off...nothing unusual. Just humming and clicks of drivetrain...all valves opening and closing fully.
