long story short,recently got 69 charger the factory gauges had been pillaged along with the dash harness,i bought a complete used cluster and a friend donated a good dash harness to the cause.With no harness in the car or gauge set i had no way of knowing if the cluster was good or not,so i went a head and refaced all the gauges,and put in all new lights,installed the harness and cluster.Seemed to go in pretty straight forward,well after trouble shooting the dash lights not working for many hours they now work,however none of the gauges work at all except the alt gauge.I get no movement what so ever when the key is turned on or by grounding out the sending units,the volt limiter has been tested and is good and i am getting voltage to the gauges,and i have ohm'd out the sending unit wires to make sure that they arent broken between the gauge and the sending units as well....how do i test to see if the gauges themselves are any good??i really need help with this thanks in advance
