- 12:51 PM
- Apr 13, 2012
- Granite Bay CA
One other thing...assuming you did both sides.
There is a right and left on the torsion bars! If in the wrong side, the clocking of the bars won't let you get the correct adjustment. Some bars are marked on one end, for which side it goes.
I have read this before but haven't found it to be 100% true. Maybe I have just been lucky ?
From 2002 until early this year, I had Mopar Performance 1.0 torsion bars in my 70 Charger. Regarding installation, I had 2 choices: I could install them so the adjusters were almost bottomed out with the car still sitting low, OR with the car sitting right and the adjuster bolts sitting below the bottoms of the control arms. Check it out:
Perhaps you have to go one more flat on the hex end. This will put the LCA down lower and be a bear to raise as their new (unsettled) torsion bars. In other words, the preload may be too light. Work safely as this can be a hazardous task.
I went back and read this post again. This is good info here.
My previous advice toward the beginning might have been wrong for a smaller, stock bar. I now have 1.15 torsion bars from Bergman Auto Craft. Pete told me for correct preload, the lower control arms are to be at full droop. The control arm socket that accepts the forward hex of the T-Bar has a "lever/finger". This is where the vehicle ride height adjuster bolt is leveraged against. That lever/finger needs to be level/horizontal. This allows the T-Bar to slide from the rear (Through the rear T-Bar anchor) to the front. Once the front hex is near the lower control arm, some "clocking" of the control arm hex socket may be required to get the hex to engage. Maybe a helper with a hammer and a block of wood at the rear might help. Two eyes on the control arm socket with a helper knocking it in at the other end??? Now knowing that you have stock bars with much less stiffness, the more correct advice might be to have that lever/finger to be resting BELOW horizontal to allow more preload using the adjuster screw/bolt.
Maybe you can post up some pictures with clear close-ups? Pictures really do help! You might be right at the point of success and some of the helpful eyes here can be what you need.
People with experience often say..."Oh, it is easy! All you have to do is....."
That can be annoying to people having trouble. These jobs are easy to someone that has done it successfully many times. Suspension/brakes/steering come naturally for me. I am just now getting better with soldering and electrical systems. I've run into problems, asked advice and felt like an idiot when guys say..."Oh, that is easy! All you have to do is...."
