Need help!!!
jtkaaa07
11:50 PM
Neenah WI
Hey guy's I'm in need of some help, I know pretty much everything about A bodies, but need some help from you experts over here on the B body forum. I'm helping a good friend work on a 65 coronet 2 door he just purchased, and he is partially handicapped ( Vietnam) and he would like to have power steering on the car. So basically what I need to know is what steering gear, pump and hose will work, or what year parts will interchange. Any help would be greatly appreciated! Obviously the car is a manual steer car just in case I forgot to mention that.
Jeff
1969 Dart GTS
Steering gear for any A 0r B body will work. A body has different pitman arm. C body unit will work, but output shaft is bigger. Some c body pitman arms will work on b body with c body unit.
318 poly
So there all the same pretty much except the pitman arm? If thats the case I have plenty of A body steering gears I just assumed they were different then B bodies.
