Canadian1968
My 68 charger came with the bendix brake setup. The rotors are shot and could not turned any more. I took the dive and bought a pair of the year one repos. I know they had bad reviews but I figured I might as well try them .
After getting them I checked them out did a few measurements and honestly they are a pretty good reproduction ! Maybe they have improved their tooling since they first came out.
But current problem is . When I install the new rotor or even now when I put the old one back in place the rotor is not centered in the middle of.the caliper. It is much closer to outside of caliper. With the new rotor being thicker it actually rubs on the caliper . And now checking the original rotor I feel that if it was brand new qnd thicker it would be rubbing to ? I was driving the car last year with no problems other than the pulsating of the warped rotors. And I can't say that I ever noticed if the rotor was perfectly centere when I took it off over the winter.
My question . Should the rotor not be in the center of the caliper.? And if so what could possibly be wrong ? It's a pretty straight forward setup .
I pretty sure I could clearance the caliper where it's rubbing without an issue, but don't understand why it is so far to one side ?
Here are bunch of pics of original and new rotors installed
