SixBarrelBill
I've spent too much money and invested too much time for my Air Grabber not to function. For the sake of argument, I'm going to refer to the toggle valve with the red handle as the switch here.
I've got a 1970 Roadrunner 440+6 that I have converted to an Air Grabber car. All new pieces and parts. Yesterday my dad and I installed all the components and spent all day diagnosing issues. At the end of the day we were finally able to get the Air Grabber to work on its own by bypassing the switch but the vacuum is too low to fully raise the door.
I want to keep the original look so I believe I have a couple solutions but wanted to see if any of you have done the same and what parts you used.
1) It seems my engine will not produce the vacuum necessary to fully open the door because of the cam I'm using. When we first hooked up the vacuum gauge I was getting about 12in. After advancing the timing a lot we were able to get close to 15in but I can't run that kind of timing normally so that's a no go.
The solution for this seems to be an electric vacuum pump. I have never used one and just guessing to successfully operate the lift on the door I would need 18-22in.
Have any of you used these types of pumps for this kind of solution?
2) I have 2 brand new switches and both of them leak so the door would barley raise. I have taken them apart, greased them up and now one doesn't work and one kind of works. I'm done with those.
The solution I would like to use is to keep one of the switches in the dash as a dummy, it wouldn't function but will look the part and mount a brass valve under the dash.
A while back I read an article (I think it was one here and wish I would have book marked it) where someone used a Clippard valve to overcome the leaking issue. I think it may have been a Clippard MJTV-5 but for the life of me I cannot find the article. Does anyone happen to have that link or have used one of these brass valves to accomplish what the original switch does?
Thanks, Bill
Thanks, Bill
