I’m planning a 500ci stroker combo with most likely the A41 kit from SST to have an overdrive. Haven’t decided if I’m gonna keep it carbureted or not, haven’t had much luck with EFI on my Camaro but if the SST A41 can be controlled by the Terminator Stealth XS Max system I may consider that route. I’m considering just trying to get a non-numbers matching car to do all the stuff to but I’m not sure. New wiring, bigger engine, overdrive trans, RTX digital gauges, LED lights in place of factory bulbs, and restore the interior to like new with a Bluetooth retro looking radio system are the biggest plans. Of course suspension needs a rebuild and I’ve been really loving polyurethane bushings on my Camaro so I’ll likely get them for the Charger in addition to larger torsion bars, thicker sway bars, and heavy duty rear springs. Also want to change up the wheels, likely in favor of Torq Thrusts or Mag 500s.That a 383 ? They can set up poorly pretty easily; kind of a misunderstood and underrated engine.
What are the big plans man?
