kevahoya
I have a 69 charger with a 383 and just installed a new pertronix plug and play billet distributor with Ignitor 3 setup and an FlameThrower III coil. "Plug and Play" is not really the case on a 69 since to install the upgrade you have to convert from the old voltage regulator to a 1970 version which then need a new dual field alternator. Ended up being a bit more money than I had anticipated (when does it not) and a lot more work since you have to combine about 5 wires into one that attaches to the new voltage regulator and run a new wire from the new alternator to the negative side of the voltage regulator. Mounting the new regulator was a little tricky since I was scared to death to start drilling new holes in my firewall but it was needed. I used a 500 degree non adhesive repair tape to re-wrap my wiring harness with the new wire and the others I replaced since the wires that lie across the intake manifold were super crispy from years of heat. After installing the my second alternator (first one was bad out of the box) I hooked everything up and prayed. It was amazing! Once we re-timed the car we took her for a drive and what a difference!! The response time was so much better. This would have been REALLY easy had I already had the upgraded charging system or a 70+ Charger but the result is tremendous and I'd definitely recommend the upgrade. Cost me $320 for the distributor and coil from Summit and $80 for the new alternator and voltage regulator from my local auto parts store along with the small cost of new wire and connectors and tape. I'll put some links to the parts I used. Hope this helps anyone else trying to convert. I'll take some pics and add them as soon as I can!!
Distributor - http://pertronix.shptron.com/p/dist-billet-mopar-383-400-black-cap-w-i3?pp=8
Coil- http://pertronix.shptron.com/p/45-000-volt-flame-thrower-iii-0-32-ohm-chrome?pp=8
Tape- http://www.amazon.com/Duck-442055-1-Inch-Single-Wrap-Fix/dp/B001B19E04
Voltage reg- http://www.summitracing.com/parts/dcc-4529794/overview/year/1970/make/dodge/model/charger
