Looking to upgrade and replace the working under the dash of me 69 Plymouth gtx I have looked at several manufacturers. But not shure which one to buy ? I would like to keep it stock so I can use all of my original insterments problem is I want a few extra circuit for add on like cooling fans for the radiator and after market gauges and steep and such. Any suggestion?
I would use the stock wiring harness. Maybe install a auxiliary fuse block and run your extra circuits through that so you don't overload anything. Using relays also helps heavy load circuits.
