arizona satellite
i have long heard that you absolutely cannot use nitrous oxide with the KB pistons, however when you get the instructions that they give you ring gap specs for a nitrous motor.so what gives? I am not talking about a huge 2 stage fogger system either, just a 150 horse plate system. I am using the KB236 pistons with the moly rings, steel crank H beam rods and stealth heads from 440 source.305 H comp cam and a eddy torkerII intake and an 850 DP.
