levicah
Ok, I've taken enough of your time, I will try to affirm the things that do work (Brakes and hazards) by testing continuity...Thank you very much...I'm "plumbing" mechanical for decades, but electrical frys me.
you can also jump out male ends to check for power up to bulbs confirming wiring is good up to bulb ends ( including bulbs )
Ok, let's see
Continuity test in female end to confirm switch is good or bad
Power test on male end is to check power arrives to tirning switch and flashers and related are good.
Ok, let's see
So, I dont know what to check next on the red wire voltage source going to the column turn signal switch...it's dead and my schematic is incomplete...it seems like voltage comes from blk wire going into the flasher and comes out red to the column harness. is that correct? if so, whats the next stop on that black wire? Assuming I am moving upstream towards the problem or lack of voltage...Sometimes doing continuity tests just messes you up. Just start looking for 12v going in and 12v at the end. I have gotten brain damaged from some of this electrical stuff over 69 yrs!
do you have voltage at radio? uses same fuse and as far I recall is spliced from same wire.
checking at flasher plug, one of them must be powered, can't recall which one ( in ACC or RUN of course ) coming from fuse box. I think should be black one, since Red one is the one running up to turning switch.
and of course you should be able to turn on your Radio ( if stock or if aftermarket but using same source! ) if not, well, there is a clue on the fail.[/QUOTE
All is well! all works fine! You dropped so many clues, it began to make sense to me. terminals at the radio fuse. I have no radio, and the fuse looked fine...I didnt know that was the fuse for the t/s until you said so this morning. Thanks again!
