devonhealth
Ground up restoration 170 gtx 426 new Ray Barton Hemi. Can not get hot water to heater core, which is new, with reconditioned heater box, A/C. Have hoses connected correctly going thru new water valve which is also working. The problem is, (and I've never seen this happen) the engine is up to operating temperature 155 degrees, but the water in the inlet hose to heater (outlet from the engine) is not even luke warm and the outlet hose from the core to the engine is cold...What in the world could be causing this??? How can engine temp be HOT, Radiator HOT to touch and the water coming off the water pump to the heater be cold. I'm very perplexed to say the least. Any Ideas befor I start pulling the water pump???? (It's new also)
Many thanks,
Dan
Many thanks,
Dan
