Not ready or put new harness in, don’t drive much at night. Going to Los Angeles in April. Don’t want to lose high beams too.
No, but when Billccm comes to town I’m good.Dude you really need to go through that wiring! I wouldn't replace the harness, just double check all your connections and repair/ modify as needed. Hope you're familiar with a multimeter !
Yea remove the dam ground terminal and why does the battery need to be connected for testing in the first place? The biggest problems I have ever seen with Chrysler wiring in our old cars has been cannibalism by idiots putting in stereo's and other electronics.You got a way to disconnect battery, just in case?
Yes.You got a way to disconnect battery, just in case?
Highly scientific procedure.jabbing a knife into the light harness connections in the bulkhead connection would bring the lights back on.
Disconnect the battery and unplug all harnesses from the bulkhead and thoroughly clean both
Male and female connectors.
Get a HALON fire extinguisher for under the driver seat if you don't have one. Today.
Be careful not to breathe in Halon....it depletes oxygen rapidly....and that includes what is in your lungs.fixed it some..
