No Power
Assuming the cables and terminals are clean. The main negative cable is clean and tight at both ends. And the battery shows over 12 volts under load (key on). I'd suspect the buckhead connector.
Doug
Well guys, thanks for your advice, tips, and suggestions. I nailed the problem. It's the damn battery!!! I figured the tender would save it but I thought wrong. The battery is not that old, but that's a $98 Pep Boys flat top special that I put the red caps on to give it that factory look. I feel like a total idiot I didn't think that thing would be completely dead with the tender sitting on it supposedly keeping it going. Thanks again for all your help, guys!!!
