Sjd556
Okay so I have a 73 charger, 383/727 that has just been rebuilt. The motor will crank fine, but I'm getting no start. Its getting good spark and fuel, but still nothing. everything electronically speaking tests good. Battery is also brand new. I started thinking it was timing and set the car at TDC, checked the firing order and all of that looked good. Rotor was pointing directly at no1 cylinder at TDC on compression stroke for cyl 1. Tried retarding timing a bit and still just crank, no start. Tried Advancing timing, got really bad compression backfire through carb. Backed distributor off. Could it be 180 out? Also checked reluctor gap, which was within spec per instructions (.008) So now I am at a loss, and am open to ideas and help..
