luckylee
68 383 with electronic voltage electronic ignition instead of points. Hi performance factory voltage regulator. Not charging. I have power and ground to the regulator. Removed green ground eire from regulator and grounded it. Still not charging. I have power at the alternator and I am assuming green wire is grounded I can’t get to it. Factory a/c car.engine turns off when negative battery terminal is dis one Ted. Amp meter works on dash. Shows discharge. Any ideas.
