Nylon insert water pump bolts
jbadams
New Member
12:55 AM
arkansas
Has anyone used these bolts for a water pump? Not sure if I want to use them with the nylon inserts as I am not familiar enough with them. The original bolt heads have worn down to the point that I don’t want to reuse them as I don’t want to strip the heads.
This is on a 65 426 wedge.
Use standard bolts with Loctite....
The nylon insert was to stop the bolt loosening......but it also weakened the bolt because now it has a hole drilled through it....
