Should I replace the filters in the muffler bearing first?Only if your Turbo Encabulator was remanufactured during the Damlier regime. If not, just clean and lube your bulkhead.
Or should I just lube the freeze plugs and be done with it?
Tapered shaft?Let me know if this what you need.![]()
Lubrication of a plug is always a good idea, without it can be a rough install.Should I replace the filters in the muffler bearing first?
Or should I just lube the freeze plugs and be done with it?![]()
Telescoping shaft, sillyTapered shaft?
Visually or physically?Tapered shaft?
Two piece or three?Telescoping shaft, silly
Spiritually.....with a spirit level.Visually or physically?
Two piece or three?
If I welded a 318 lifter onto the side of it and bent the pinion at 45 degrees from a C-Body car, would the muffler bearing still need regular greasing?Two for a B-body. The three is a one-year-only C-body item. The B-body and C-body parts are not interchangeable and neither one can be retrofitted to an A-body.
Spirits change everything.Spiritually.....with a spirit level.![]()
OJ is going to sweat more now than he did running to the Hertz rental car counter at the airport!
Retribution from the grave.Don’t know if you guys have seen the latest articles on ESPN regarding the Simpson estate attorney and executor steadfastly stating he’ll do everything in his power to ensure the Brown/Goldman families get zero from the estate regarding the $33.5m judgement against the murderer from the civil suit conviction after the criminal trial fiasco.
