SOLD OEM factory rear sway bar powdercoated
hammond472
12:41 AM
Los Gatos
Feedback: 1 / 0 / 0
Improve your handling for cheap or replace your missing one. Factory rear swaybar bar and hardware powdercoated satin black. Also has new nuts and bolts. $125. plus the ride.
It fits 60-76 A body and 65-70 B body. It came off a 70 Roadrunner. I bead blasted, powder coated and replaced the hardware. You will need the u bolt mounts if your car did not come with one from the factory. The factory rear bars are getting harder to find.
Is this is an aftermarket bar or an original from a E or 3rd gen B setup for the cars you listed?
You sure that's "oem"?
It was pulled from my buddys 70 Roadrunner when he 4 linked the rear. I'm going 4 link as well so I won't need it. It is a stock bar. It just looks nice due to the powder coating. Looked like crap when I got it.
Not saying your wrong, but I don't recall any b body with a rear sway bar from the factory, an e body, yes, but not an b body. Also an e body rear sway bar would be bolted to the leaf spring plate. I think you have an aftermarket bar there cause the links look just mine that I got from just suspension. Might want to do some research on it as it does look like an addco bar.
And I've never seen a rear bar on a 70 E body...just 71 up E's....and I've had several 1970 E cars. Even my 340 70 Rallye Pack didn't have a rear bar but it came with just about everything else on it including rear window louvers and luggage rack. Just thought I'd mention that. Didn't have very many B body cars but parted a few and never saw one on them either during that time.
Wasn't the T/A and AAR available in 70'?
I was told it was a factory bar but it does look like an addco bar. I am not sure so I will drop the price to $75. plus the ride
