dusterkid
Is there any downside to running a smaller oil filter like Wix 51085 vs the larger Wix 51515?
Smartest part, right there. Fram hasn't been Fram in a long time now....No more Fram!
It'll only bypass if it's restricted. It's only restricted if it's dirty. The bypass setting on the 51516 is 16 psi. All other Wix filters that fit Mopar V-8 (small or large) are 8-11 psi bypass. Including the 51515R race filter.As big of filter that I can fit on every vehicle I own. The little ones most likely don’t affect flow because they go into bypass sooner than a larger filter with more media. Why run a filter if it’s bypassing?
Sometimes clearance is an issue. This engine has run the "tiny cute little filter" since 1991. Street car with plenty of 11.0 passes on it. I'm may not qualify as an expert either. But I do have a lot of experience building race motors over the last 30 years. Worked in the automotive repair field starting in 1974 as a ASE Certified Master Tech until 2021.I’m no expert this just the thoughts of a blue collar farm boy turned lineman.
Sure, dirty oil, cold oil, a high rpm event where the pump moves more oil than the media can flow, filter can bypass. Being thats there is not a indicator for when it is in bypass, I will error on the side of caution and use a big filter with lots of media when 1 is available. Feel free it use a tiny cute little filter its your engine.
51515 R also has a media that filters at a larger micron rating, thus flowing more oil, less likely to bypass.
It's a smallblock.Just curious. Whats causing the clearance issue on that engine? Looks like a manual steering box. The crank pulley doesn’t look to be interfering. Lower rad hose is the same Im guessing, I can’t see clearly on my phone.
The headers. Bigger filter fits fine. But you can't pull it out of the headers once it's off.Just curious. Whats causing the clearance issue on that engine? Looks like a manual steering box. The crank pulley doesn’t look to be interfering. Lower rad hose is the same Im guessing, I can’t see clearly on my phone.
