Huicho417
- 11:41 AM
- Sep 15, 2020
- San Antonio , Texas
Last year I dealt with the dreaded rear main seal leak on my coronets 318. After trying four different seals I was able to stop the leak. A couple of weeks ago I noticed a drop of oil at the bottom of the bell housing and panicked! I removed the transmission inspection port and no oil buildup inside the bell housing. Which is where it accumulated when it was the rear main seal leak. I traced the leak this morning and have a lot of buildup around the oil sender and distributor base. I did install an extender to add an oil pressure gauge. I remove that and added some Teflon. My distributor does have a metal gasket that has a small ridge down the middle. Should I add a separate gasket under the distributor? I did use my snake camera to check the rtv under the back of the intake and does not look like the leak is coming from there.
