JG71B
I've had this thing apart a couple times and can't figure it out. Oil keeps pooling up right underneath it in the corner of the block, everything's nice and not too tight, holds timing good, easy to adjust, I don't get it, anybody got any ideas? I have no other leaks besides this. It's not coming from the hold down at the Valley Pan either, the inside of the distributor is coated with oil and seems to be leaking out of the small hole in the bottom floor of it. Is there a gasket or an O-ring I'm forgetting about? Seems to be pulling up from the shaft and getting through the top somehow , the cap isn't soaked but the bottom inside of the distributor is. I've read a few times there is a round o-ring and a square o-ring for the base of the distributor to the block , but not sure. Appreciate any help
