you could add a mechanical gauge to see if nornal
You asked about oil level. And im pretty sure dadabee's response was to that. And since we have all types of folks on here, you did mean oil pressure level when you asked? Because that's what that guage indicates, not the level of oil in the engine. And oil pressure is influenced by engine temperature and oil viscosity.Is this normal level for oil ? At one point I remember being it on the high end .
Nothing wrong with that - it's not zero, and it's not maximum.Is this normal level for oil ? At one point I remember being it on the high end .
...and confirm the dipstick is the correct length. Longer dipstick might make the reading higher.The first step is to ALWAYS confirm with a known good gauge…
FYI, that is pressure and not level. Factory gauges are just a guess. One step better than a idiot light. Like suggested, put a good manual gauge on it to test or install a gauge for a permanent look. 10# at idle is my minimum. Most engines run around 50# at rpm. (2000 or more)Is this normal level for oil ? At one point I remember being it on the high end .
Dang, I didn't backread.Since the OP posted a picture of their oil pressure gauge, I assumed that they meant pressure instead of level.
Did you get the answer you were looking for?Is this normal level for oil ? At one point I remember being it on the high end .
Yes thanks I was confusing the oil level with the pressure . I asked because I have never seen the pressure that low before it's always on the higher end.Did you get the answer you were looking for?
oil old or low? Maybe time to change it.Yes thanks I was confusing the oil level with the pressure . I asked because I have never seen the pressure that low before it's always on the higher end.
