Purepony
So I had a leak in the oil pan but it wasn’t too bad the. I replaced my breather on the valve cover, replaced the water pump, belts and hoses and next thing I know the oil pan started leaning pretty bad.
I removed it and I did make a mistake by not really cleaning under the block I did wipe but didn’t clean it and o feel like some oil residue stayed there.
The bolts in the front are hard to get to and I don’t think I tightened the bolt to 15 lbs as stated so drove around and it leaks again and just as bad as before. I’ve done oil pan gaskets before and they’ve never leaked but only on ls engines and the engines were out of the car so I was able to use a torque wrench
should I
a) retighten the bolts and use silicone on them since it had it before. it seems every time after a drive the bolts get loose. I check them and they’re loose every time since I did the gasket.
The what was a new gasket did get wet with oil
B) remove the whole pan again and do the job by cleaning the block with some brake cleaner or alcohol, use the 90 min gasket ultra black in the front under timing cover and a get new fel pro gasket
c) do a Tesla engine swap lol I wish just so I wouldn’t have to deal with gaskets and oil anymore haa! Kidding
d) what would you do ? Any recommendations
Thanks. My car and I thank you
should I
