Oil Pan Power Package 6QT
FlagCraig
3:24 PM
Tennessee
Any one use the Mancini Power Package? It has the stock look which I like.
Includes oil pump pick up
Milling Oil Pump
Windage Tray
Oil Pan 6Qt.
Going on 440.
Got one but not from Mancini. It is just a Hemi style pan. Works well and gives peace of mind with the extra oil when running a HV or Hp pump. Shop around. I used the standard pump with a black high pressure spring. Make sure you pull the pump apart to check for crap from machining.
and detail all the square corners, match the oil holes, etc and the suction side makes more difference than the pressure side
HP spring depends on what clearances you run which also determines what weight oil you need
you should not need HP spring with stock clearance (also depends on rpm I'm thinking auto trans and street gears)
but stick a mechanical gauge on before doing anything
lucky Mom Mopar gave us an easily adjustable oil pressure spring.
windage tray?
