Take a jumper wire with you. Next time when the Gauge reads zero leave the car running. Make sure the mechanical gauge is showing pressure. Then attach the jumper to the sender wire. Leave the plug on the sender and ground the other end of the jumper. The gauge should peg. If it does it is a sender problem. If it does not its an electrical problem. Can you post a picture of your sending unit set up?
