mikeymopar
Getting the Charger back up and running after 30 years of sitting. Engine gone thru and running good. Moving on to the trans (A727 with a Stage 3 shift kit) and doing a quick filter and fluid change, I've read countless debates on types of trans fluid. Conclusion is keep it fresh and use whatever going by the plethora of comments. I've not seen a definitive answer on the mixing of old, straight up Dexron with ATF+4. Possible to mix the two types for a little while before doing another fluid change with more ATF+4? Or stick with something like a Castrol Transmax Dex/Merc (can get locally at a decent price) for compatibility sake with the old remaining fluid?
