tirefryin-Bob
Here's the skinny, have a 440 +.060 runs real rough at idle (Almost stalls) but will smooth out above 1200 rpms. has a rebuilt carter 750 AVS, stock compression pistons, mopar hp/road runner cam, stock duel exhaust, rebuilt stock 906 heads, mopar elect. ignition. timing @ 10' btc.
Must be a vacuum leak right?? "Wrong", well lets say if it does I can't find it, I sprayed carb cleaner while it was running all around the carb & intake with NO change in eng. rpm or the rough idle.... I hooked up my vacuum gauge to the intake and here's were it through me for a loop, only 5 inches Hg of vacuum !!!! So far everything I've read points to a severe vacuum leak or valve timing (not ignition timing) being off, well since I can't locate a leak must be valve timing. My first though was bad or jumped a tooth on the timing chain, so off comes the timing cover only to find the double roller chain is still tight and spot on TDC with gear timing marks pointing right at each other..
So if I don't have a vacuum leak and the valve timing is correct, What ELSE could be causing such a low idle vacuum???
above 1200 rpms the engine vacuum climbs up to 16 inches inches Hg.
Please HELP!!!
Please HELP!!!
