One legged
Roger63
7:30 PM
Skiatook ok
Is there a way to turn a 8.75 open to a posi without replacing the entire center section?
change the guts to a sure grip still not cheap. but cheaper if you can find a used one in good shape.
If you mean without 'removing and re-installing' the center section, the answer is no. But you can swap out the open carrier with a limited slip unit, retaining the current gears and not touching the pinion gear at all.
