I am running that same cam in my 440 source 512 street car, 9.7 compression, work greatI have spoken with Hughes, who designed the cam I am considering using. They recommended it for a 500+ CI motor with 11:1+ compression and mechanical secondaries on the carb.
My 400 block just got checked and is good for the bore needed for the stroker kits. (4.375 I believe)
I do plan on using aluminum heads, which I hear can basically “take off a point”.
Hughes sells a 400-511 kit that would put me at 11:1 without zero decking the block. 440 source offers a 400-512 kit that could be 10.5:1.
I will post a photo of the cam card. Hughes seemed to think with the low altitude here and the abundance (as of now) of 93 octane gas, that 11:1 on pump gas would be doable.
The car won’t be a daily, but will probably see more street than track. Would you say 11:1 could work safely with the cam, or is it better to try 9.5-10.5?
I have heard some people say 11:1 makes the tuning window very narrow, however there are plenty of cars from the era that cam with 10.5:1 and iron heads back then. I’m assuming it should be fine, but I just want to verify.
Any videos? How does the idle sound?I am running that same cam in my 440 source 512 street car, 9.7 compression, work great
You can get away with higher compression and help avoid detonation by using flat top pistons with aluminum heads providing quench and a cam big enough to bleed a little compression at slow speeds
currently running 440 with old TRW dome, 906 heads and cam 284/294 @ 0.50. So maybe 11.6 or so on 92 octane here. Can tell who has best gas as some brands can detonate on hot days.
Also noticed at elevation 3000’ is less likely to ping compared to 500’
Street car on pump. Why take a chance? Build it 10.5-1 and give yourself a little cushion. The power difference between 10.5-1 and 11-1 isn't going to be more than 15-20hp. Now if it was a racecar? I'd make it 15-1
Doug
Excellent advice.If you are in the planning stages, now is the time to make the right decision. Err to the side of caution. Whatever slight gain you might see in 1/2 to 3/4 of a point in compression severely pales in comparison to knocking, pinging, destruction or mixing fuels. Screw all that.
I trusted a known supplier that assured me that I’d run fine at 10.8 with 91 octane. I didn’t. Mine knocked at anything over half throttle. I’m st 10.1 now and rarely get any detonation even in 110 degree weather.
Advice online is cheap. This is one instance where it makes sense to play it safe.
This is an old video when it still was carbedAny videos? How does the idle sound?
