Well, after some testing, how-to on this forum, I solved my overcharging problem. My 69 RR 383 4 speed was getting 14.5v idling and over 15v 3000rpm. With the testing I saw my FLD wire getting 11.5v which would explained the overcharging. I tried two regulators and received the same thing. I finally found a solid state regulator that has volt set at 14.5 and was only $8.99, I know, pretty cheap but it worked. With the car warmed up the car gets 13.9v at idle and at 3000rpm it gets 14.4v. I tried 4000rpm and it stayed at 14.5v. Not bad for a cheap regulator, hard to find one with a volt set of 14.5, actually its the only one I found. If your looking for one I got this one at 230-10001 Mopar Chrysler Dodge Voltage Regulator Electronic Solid State.
I also bought a 1970's style adjustable electronic regulator that I may use with a 2 FLD 95amp powermaster ALT that I have. I might change it over later because I found that everyone said it was a better choice but we will see. Over the last two weeks I solved a overheating and a overcharging problem, what a relief!
