Well, since this thread is still alive and has somewhat run off track from the original poster's question, I will direct those interested tp this Moparts thread.
Here is a copy and paste from one poster there regarding this, but I also encourage people to read ALL of the peoples posts that have purchased both the Passon and Keisler O.D. units.
Having driven several Kielser equipped cars and a couple Passon trans cars, here's my .02.
1. For a true "no hack" install the nod CLEARLY goes to Passon
2. If you drag race you'll like the Passon, the Kielser is not a fast shifting trans, a bit too sluggish and notchy, especially at higher RPMs
3. If you want the strongest trans, Passons will take more HP than a Kielser by a fair margin
4. For cost and ease of install, Passon wins
5. For the best highway crusing O/D situation, Keisler wins due to it's better high gear ratio
6. Fuel milage Kielser also wins, same reason
7. Service - Passon hands down
8. With a 3:54 geared car that you do not want to modify beyond clean/simple easily reversable bolt ons and is mainly street driven and occasionally drag raced - Passon
9. For a modified car that is mainly used for local car shows, street cruising, taken on a good many long highway runs and not much else - Kielser
10. If considering these two companies you should also look into Gear Vendors and Classic 5 Speed before buying, may as well see what everyone is selling before you pull the trigger. I have also driven Gear vendor equipped cars, they should be a consideration for sure, they make a good product.
Here is the link to the entire Moparts thread:
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=4787748&an=0&page=1#Post4787748
