FOR SALE Parting 68 satellite convertible
Do you have the clips that hold the screws for the belt molding ? The are 3 per side and is behind the door panel
Nothing extra but in pretty sure that charger uses the same clip
Hello,
I am looking for the metal splash shields that mount just above and behind the headlights. They install from inside the fenderwell - these are the removeable shields that the rubber "C" shaped shields attach to.
Thanks.
Satellite has a plastic shield behind headlight
A good one? Or a core? They’re available new pretty cheap but prob got one
how is the steering wheel ?if good send pic please.
Do you have the dash trim pieces? Condition if so? Thanks
Which dash trim pieces?
Looking for unbent door and quarter window cat whiskers. Inner and outer.
The plastic pieces with the ribbed looking stuff underneath. One of them is the big one with the 'satellite' emblem in it, the others are smaller..I think there was one that went around the radio area too.
I’ll check I think it was junk
Any chance you have the screws that hold the belt molding on and the fasteners that hold the pillar trim on? Thanks!
A pillar? Interior or exterior? The belt molding sold already
Do you have the sheetmetal piece that the door hinges bolt to? it looks like the piece in this link: https://www.jegs.com/i/Golden-Star/189/PL08-68R/10002/-1
The one on our 70 RR on the right side is very rusted.
Hopeful you will have it as you said the middle portion of the car was not too bad. We will be traveling up to the states in late June to the CT area. Would be willing to remove the piece myself if it is available.
Best regards,
David
