Original battery tray and one of the s-brackets for it? Looking for battery hold downs as well and bolts if all good.
Tried to send a PM but your inbox is full.
If you're still looking for the battery tray "S" bracket let me know have several
I cut the entire core support out of the car, if you are interested.Looking for the top rail for the radiator core support - original owner hacked mine out. I'm pretty sure the rails are same in big and small rad cars but I need enough to bridge the 26" radiator opening with some length to spare.
Yes, I already cut those out.Do you still have the hinges that mount to the wheel wells for the trunk?
I do have that, but one corner is damaged. It looks like it can be restored.Do you still have the sorround trim for the rear trunk panel?
If so I am in need of one. Thanks
Thanks - I actually found some in a junkyard not far from me, heading to get them Monday. If they don’t work out I’ll check back in.Yes, I already cut those out.
